东莞市宝桢研磨机械有限公司
Vibratory Grinding Machinery Co.,Ltd.
主营:全自动振动研磨机,全自动涡流式光饰机,离心式研磨抛光机,工业脱水烘干机,八角六角滚筒研磨抛光机,各类研磨抛光石,各类研磨切削抛光液,振动研磨机包胶
脱水烘干机、脱水机、热风干燥机、工业脱水机、脱水干燥机
发布日期:2020-09-24 来源:东莞宝桢研磨机械有限公司 作者:殷生
不锈钢脱水烘乾机
脱水、烘干同步进行,无水渍及污点出现,可避免工件氧化或生锈,提高成品光泽度及质量;脱水槽为不锈钢材质,坚固耐用,内篮可提出,方便工件装取;设有脚踏式煞车器,提高使用的安全性;采用自动控制的电源系统,脱水烘干完成打开铝盖时,自动切断电源,本机采用铸铁底座,重心稳,内外筒采用不锈钢制成,坚固耐用;加热器装配在上面铝盖,直接加热,电源及煞车系统均采自动控制。
特点:
适用于各种金属零件经研磨,油洗水或浸防锈液后脱水烘干用;各电镀及研磨加工厂,烘干必选机器
功能:
1、脱水、烘干同步进行,无水渍及污点,可避免工件氧化或生锈。
2、脱水槽为不锈钢材质,坚固耐用,内篮可提出,以利工作装取。
3、设置脚踏式刹车器,提高使用的安全性。
4、采用自动控制的电源系统,脱水烘干完成或打开铝盖时,自动切断电源。(温度控制、时间控制等功能可选)
Stainless steel dryer
The dewatering and drying simultaneously, water stain and stain, can avoid the oxidation or rust, improve product quality and gloss; dewatering tank is made of stainless steel, durable, can be put inside the basket, convenient workpiece; a foot brake device, improve the safety of use; the power supply system of automatic control and dehydration dry finish open aluminum cover, automatically cut off the power supply, the machine adopts iron base, center of gravity, the inner and outer cylinders are made of stainless steel, durable; the heater is installed on the upper aluminum lid, direct heating, automatic power and brake control.
Characteristic
Applicable to all kinds of metal parts by grinding, oil or water immersion after dehydration and drying with anti rust liquid; the electroplating and grinding processing plant, drying machine necessary
Function:
1 dehydration and drying simultaneously, waterless stains and stains, to avoid oxidation or rust.
2. The sink is made of stainless steel. It is durable and the inner basket can be raised for working.
3, set foot brake, improve the safety of use.
4 automatic control of power supply system, dehydration, drying completed or open the aluminum cover, automatically cut off the power supply. Optional functions such as temperature control and time control.
Model
Motor
(HP)
Barrel Diameter
(mm)
Barrel Height
(mm)
Speed
R.P.M
Heat
 (kw)
BD-400
260
530
1.8
BD-500
1.5
500
280
530
3
BD-600
3
600
350
480
4
关键词:
Drying and drying machineIndustrial dehydration drying machine
Customized dehydration dryer
东莞市宝桢研磨机械有限公司
